Separate First Name, Last Name fields
How do I add/change default form in Contact Form to make "Contact Name" to separate First Name, Last Name fields?
Click the edit button next to Simple Contact in the CSS Form Builder wizard.
Select Group 1, then click the Edit button again.
Line 1 -> Set 1 contains the name field. Change the label to "First Name"
To add the last name field, select Line 1, then click the plus button and select Line.
Select the field that is added to line 2 and change the label to "Last Name"
