Dreamweaver Site Definiation
Thread began 6/15/2010 12:46 pm by larry268887 | Last modified 6/15/2010 11:40 pm by larry268887 | 1059 views | 2 replies |
larry268887
Here's the problem there is so much conflicting information on how to set up a Deamweaver Site Definition it's no wonder that cssmenu writer is not compatible with site sculptor.
I've used these documents as reference.
dynamic_site_definitions.php
?id=vid0162
Adobe Dreamweaver Help
Lets first start with the remote info tag.
1.FTP Host
A.Both adobe and webassist agree that the FTP host should be the path that the hosting company provides.
2.Host Directory
A.Adobe says that this field Should be the directory that the hosting company provides you as the directory that the files are to be published to.
In my case it is elvis-parti-yorkies.com/
B.Webassist says "Leave the Host directory field blank"
I have two different websites hosted with two different hosting companies and if you leave this field blank and try to upload files to the server thru dreamweaver the files will not go into the elvis-parti-yorkies.com/ folder. I uploaded a file named test.php using this method and when you put test.php in the address bar of your browser you get the following error The requested URL /test.php was not found on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. If you use Adobe's method the file will be found.
Conclusion:
On this point I would say that the information that webassist supplied is incorrect.
Now let's move on to the Local Info Tag
1.Local Root Directory
A. Both webassist and Adobe agree on how this field is to be filled out.
In my case this would be: C:\program_files\wamp\www\elvis-parti-yorkies.com\
2.HTTP Address
A.If the remote info tag was filled out first and you used Adobe's method the HTTP Address will be already filled in for you and it will be elvis-parti-yorkies.com/
If you used webassist's method on filling out Host directory on the remote info tab the HTTP Address will be already filled in for you and it will be ftp.elvis-parti-yorkies.com/
B.Webassist says "In the HTTP address field enter the localhost/ address to this folder. This will be something such as ’directoryname’ where ‘directoryname’ should be replaced with the sub-directory you just created."
Conclusion:
Dreamweaver ignores the (ftp.elvis-parti-yorkies.com) so the remote route for $WA_remoteRoot
1.elvis-parti-yorkies.com/ = /elvis-parti-yorkies.com/
2.elvis-parti-yorkies.com/ =/elvis-parti-yorkies.com/
3.ftp.elvis-parti-yorkies.com/ = /
4.localhost/ = /
Based upon what webassist says in their dynamic_site definitions.php file and how dreamweaver automatically fills out the http adress when the remote info tag is filled out using the method Adobe recommends the correct HTTP Address = elvis-parti-yorkies.com/ or elvis-parti-yorkies.com/.
It should be noted that if the HTTP Adress is filled out in this manor and one uses CSS menu writer the links that are generated will be wrong on the live site. Css Menu Writer uses what is after the (ftp.elvis-parti-yorkies.com) in the HTTP address field to determine the $WA_remoteRoot variable. The links will look like as an example: test.php instead of test.php.
Finally the Testing Server Tab
A. Both Webassist and adobe agree on how the testing server folder and the URL Prefix should be filled out.
Conclusion:
If on the URL Prefix field, if what is after localhost doesn't match what is after ftp.elvis-parti-yorkies.com in the HTTP Address field on the Local info tab you will get this message: The site URL prefix[/elvis-parti-yorkies.com]for the testing server does not match the site URL prefix[] specified in the HTTP Address for the site. This may cause pages using site relative links to display incorrectly at runtime. Further conformation that the correct way to enter the HTTP Address in my case is: elvis-parti-yorkies.com/ or elvis-parti-yorkies.com/.
It should be noted that CSS Menu Writer uses what is after localhost in the URL Prefix on the Testing server Tab to determine the $WA_localRoot. As an example: If your URL Prefix is elvis-parti-yorkies.com/ then $WA_localRoute= "/elvis-parti-yorkies.com/".
Reccommendation:
1.First Webassist, based upon Adobe recommendations, needs to determine the proper way to Fill out the Dreamweaver site definition.
2.Once that has been determined then they need to correct all their documentation so as their are no conflicts.
3.Then if necessary they need to recode their extensions based upon their standard published Dreamweaver Site definition.
If I'm wrong if what I've stated please point me to the correct documentation.
Thank you for the feed back on the documentation, I will forward your comments to the documentation team and we will review the documentation.
to address your points:
You should start on the Local Info Tab.
enter your local path and the correct HTTP Address to your site.
If you start on the Remote Info Tab and enter you FTP Details, Dreamweaver will try to "guess" at your sites URL, and incorrectly add it using the ftp address.
The HTTP Address should be a valid URL to your site:
www.elvis-parti-yorkies.com/
you should be able to take the address entered fort the HTTP Address and put it in the address bar of a browser and browse to the site.
After completing the Local Info section, progress to the remote info Section.
For the Host Directory, adobes recommendation is correct, use the directory that the hosting company provides you as the directory that the files are to be published to.
On the testing server tab set the URL Prefix to use the correct URL to connect to the local site.
The alert that you are mentioning:
will only have a bearing for site relative links:
"This may cause pages using site relative links to display incorrectly at runtime"
it will only come into play if you have set the "Create Links Relative To" option on the Local Info tab to "Site" instead of "Document". this should be avoided since it will cause problems with PHP.
The two main Site definition settings that effect Menu Writer are:
Local info: HTTP Address
Testing Server: URL Prefix
When entering these in the site definition, make sure they are correct and that you can enter them into a browsers address bar and get to the correct place.
larry268887
Jason thanks for the reply. Your response was well thought out and provided enough detail that anyone should be able to complete the site definition. I hope webassist takes a look at their on documentation and updates it so other people have something correct to follow.
Again Thanks
Larry
