Daily Chart Page
When I click on the monthly orders or user registrations from the dashbord page, the page that comes up looks like the attached. What is supposed to be there and how can I fix it?
Thank you.
Thank you.
You are supposed to see the charts for the daily orders or daily registrations. You're seeing the charts for the monthly statistics for those two, is that correct?
Did you make any modifications to any of the pages before uploading?
I see the monthly stats on the actual dashboard page. When I click into it is where I don't see anything. That would be this page: orders_Chart_Daily.php
I did not alter this or the home page of the admin section.
Make sure that all the files in the DynamicWebCharts directory is uploaded. The files for the daily charts may not have been uploaded correctly.
I reuploaded the whole folder. Same results. Now what?
Can you send me your orders_Chart_Daily.php so I can take a look at it?
This could have something to do with how your database server is set up as well. Not sure why it would not be showing up if the monthly charts are working still though.
I've attached that file. To be clear, what works are the charts on the home page of the admin. Both of those no longer work when you click through to the attached file.
I've opened a backend ticket to look into this issue with you further. To check your backend ticket, log in to your account at www.webassist.com and check your support history.
