MySQL Error#:2005
Unknown MSQL server host "locialhost" (11001) any help please?????
change the server name from "locialhost" to "localhost" (without the "i")
Thaks i have done that i now get this error and also when i add an item to cart and check out there is no image and no price????
Fatal error: Call to undefined function curl_init() in C:\xampp\htdocs\low_cost_design\WA_eCart\Adv_CO_Scripts\PP_PayProUK_PHP.php on line 138
In the add to cart buttons, make sure to bind the price and thumbnail cart columns to the correct columns from the order table.
For the error, you need to enable cURL in the php.ini file, see the following thread for details:
t-13039.html
Sorry do you mean in the add btn bit??? and is that where i add a price and item ?????
how to add items and price???
In the eCart Add to cart button server behavior, on the Bindings tab, you can specify the price.
ok but if i have to clice on the bult to add Default Valus then where dos the price and how do i bined the produck to it or do i need another program????? i only have ecart 4
see the eCart getting started guide for details, it walks through the process of adding the eCart add to cart button and setting up the bindings.
