Navigation not working
Thread began 6/10/2010 9:05 am by larry268887 | Last modified 6/11/2010 7:25 am by larry268887 | 4760 views | 7 replies |
larry268887
I know this is not a problem with site sculptor and it is probably something I did wrong.
In dreamweaver the links are set up as relative to document and the site name is Parti Yorkies.
The host has the website folder as elvis-parti-yorkies.com so all my navigation contains
Parti Yorkies/filename.php. Since I don't have any folder parti yorkies on the remote site one can't find the file.
What did I do wrong and how should I correct it?
Larry
Jimmy Wu
The url that is used by Site Sculptor is in your site definition in the testing server portion. You would want to change the URL Prefix for the testing server. Try that and see if the value is getting set correctly.
larry268887
That doesn't work Now the home page is all messed up.Now the local site doesn't work and the remote site doesn't work. can you please call 573-734-6330.
Jimmy Wu
What did you change the site definition settings from and what did you change them to?
Could you elaborate on how the sites are not working?
If it is necessary, we'll get into a phone call, but as of now, its not at that stage yet.
larry268887
changing the site definition is not the solution. Even if it worked it would still give and extra level in the address which is unacceptable. You will also have all the files that the original site description. I have two other sites and the site description has never been the same as the remote folder.
larry268887
The server testing folder C:\program_files\wamp\www\Parti Yorkies\
The URL prefix is Parti Yorkies/
I changed them to
C:\program_files\wamp\www\elvis-parti-yorkies.com\ and
elvis-parti-yorkies.com/
Once I did this nothing worked because there are a number of files such menu.php
which still has rwmote route as Parti Yorkies
larry268887
source code for menu on local host
<div id="topNavigation"><ul class="level-0" id="cssmw3">
<li class="parent"><a href="/Parti Yorkies/partiyorkiesforsale.php">Parti Yorkies For Sale</a>
<ul class="level-1">
<li class="parent"><a href="/Parti Yorkies/partiyorkiesforsale/partipuppiesforsale.php">Parti Puppies For Sale</a>
<ul class="level-2">
<li><a href="/Parti Yorkies/partiyorkiesforsale/partipuppiesforsale/puppyforsale.php?Id=3">Allie</a></li>
<li><a href="/Parti Yorkies/partiyorkiesforsale/partipuppiesforsale/puppyforsale.php?Id=1">Hannah</a></li>
<li><a href="/Parti Yorkies/partiyorkiesforsale/partipuppiesforsale/puppyforsale.php?Id=2">Madlin</a></li>
</ul>
</li>
<li class="parent"><a href="/Parti Yorkies/partiyorkiesforsale/partiadultsforsale.php">Parti Adults For Sale</a>
</ul>
</li>
</ul>
</li>
<li class="parent"><a href="/Parti Yorkies/partiyorkiebreeders.php">Parti Yorkie Breeders</a>
<li><a href="/Parti Yorkies/partiyorkiebreeders/malepartiyorkies.php">Male Parti Yorkies</a></li>
<li><a href="/Parti Yorkies/partiyorkiebreeders/femalepartiyorkies.php">Female Parti Yorkies</a></li>
</ul>
</li>
<li class="parent"><a href="/Parti Yorkies/photos.php">Photos</a>
<li><a href="/Parti Yorkies/photos/nurserypicturegallery.php">Nursery Picture Gallery</a></li>
<li><a href="/Parti Yorkies/photos/pastpuppiespicturegallery.php">Past Puppies Picture Gallery</a></li>
</ul>
</li>
<li class="parent"><a href="/Parti Yorkies/information.php">Information</a>
<li><a href="/Parti Yorkies/information/aboutus.php">About Us</a></li>
<li><a href="/Parti Yorkies/information/contactus.php">Contact Us</a></li>
<li><a href="/Parti Yorkies/information/adoptioncontract.php">Adoption Contract</a></li>
<li><a href="/Parti Yorkies/information/shipping.php">Shipping</a></li>
<li><a href="/Parti Yorkies/information/studservices.php">Stud Services</a></li>
<li><a href="/Parti Yorkies/information/privacypolicy.php">Privacy Policy</a></li>
</ul>
</li>
<li><a href="/Parti Yorkies/shoppingcart.php">Shopping Cart</a></li>
</ul>
Source code for menu on remote server
</ul>
</li>
</ul>
</li>
</ul>
</li>
</ul>
</li>
</ul>
</li>
</ul>
</li>
</ul>
The menus are the same the only problem is there isn't any Parti Yorkies folder on the remote server.
larry268887
Bugs In Menu writer and site sculptor
Here are three threads with the same problem.
showthread.php?t=13609 6/7/10
showthread.php?t=12437 4/24/10
showthread.php?t=11850 4/6/10
Menu writer uses the Http address on the local info portion in dreamweaver site definition to populate the variable $WA_remoteRoot in the menu.php file that is created by menu writer.
If you follow webassists directions on defining a site doc...efinitions.php your local route folder might be something like this C:\program_files\wamp\www\Parti-Yorkies\ and your Http address would be something like Parti-Yorkies/.
If you set your site like this then menu writer will assign $WA_remoteRoot = 'Parti Yorkies'
When you go to upload you files to your remote server the menu will no longer work even tho it worked on your local host.
To get the menu to work you must go into the menu.php file and set $WA_remoteRoot= '/'.
It should be noted that THIS FIX WILL NOT WORK IF THE SITE WAS CREATED WITH SITE SCULPTOR.
Another Bug in menu writer is if you have two sub-menus that are dynamic.
The first dynamic menu is correct but the second dynamic menu isn't.
Menu writer frees the second data base before selecting the database.
To correct this one must edit the menu.php file.
the following code (as an example)
mysql_free_result($menuwriter_products);
must be placed after the </ul>after the fetching of the items on the second menu.
This first bug has been reported on 4/6/10 that I'm aware of. Why hasn't webassist addressed the problem? This takes a customer a lot of time to track down the problem that is not my responsibility.
How long will it take to resolve the bug in menu writer when used with site sculptor?
Edit/Delete Message
