Subquery returns more than 1 row
Thread began 6/08/2010 10:06 am by rob294118 | Last modified 6/09/2010 5:12 pm by Ray Borduin | 1479 views | 7 replies |
rob294118
I'm getting this error all of a sudden:
I can't even re-install anything because this error comes up. If I delete all of the items in the products database, the error goes away. When I add a product back, the error returns. I already inputted the products twice and don't want to do it again.
site: www.getfitlookgreat.com
I have opened a support incident so that we can work with you directly to make sure this issue is resolved.
What page do you see that error on? I looked for it on the site and couldn't find it.
rob294118
I deleted the all of the products so I could work on the site.
It is probably a simple update to the query that will fix the problem. However there may also be an underlying database integrity issue I'd like to investigate.
The support incident will remain open. Please update it if you run into this problem again and we can work with you to diagnose it and find a permanent fix so it won't happen again.
rob294118
It still is an issue. I can't add any products. What do I need to do?
Go to the support incident section of our web site and update your incident to include a phone number and good time to reach you.
We'll give you a call and try to sort out what is causing the problem over the phone.
rob294118
Did this already.
Somebody will call you today.
