data assist back end
Thread began 6/08/2010 12:48 am by joellegolds150659 | Last modified 6/08/2010 3:33 pm by Eric Mittman | 528 views | 1 replies |
joellegolds150659
I am new in php and mysqual
How can I change the value of a number with the dollar sign example
it show 5 I will like to see $5.00 and not 5 only in the result page
also
how can I change the result of the online to answer yes or no instead of number id value
using
php v5.4
windows 7
dreamweaver cs4
You can format the results so that you get $5.00 adding a dollar sign where the value would display, then using a decimal formatting function to add the .00 to the number. This will require you to make the changes in the code on your results page. Here is a link to the number format function page so you can see how that works.
php.net/manual/en/function.number-format.php
If this is something that you would like help with to implement post back with your results page and I will show you where to put the code.
