Session Variable - Ecart - Not working
Hi
I am having trouble setting up a session variable to apply a charge of a value is greater then 6 in a selected drop down.
I have set up a drop down list on my order page: order-indoor.php
<select name="CanuckHTC_15_SkirtLength_Add" size="1" id="SkirtLength">
<option value="No Skirt">No Skirt</option>
<option value="1">1</option>
<option value="1.25">1.25</option>
<option value="1.5">1.5</option>
<option value="1.75">1.75</option>
<option value="2.0">2.0</option>
<option value="2.25">2.25</option>
<option value="3.0">3.0</option>
<option value="3.25">3.25</option>
<option value="3.5">3.5</option>
<option value="3.75">3.75</option>
<option value="4.0">4.0</option>
<option value="4.25">4.25</option>
<option value="4.5">4.5</option>
<option value="4.75">4.75</option>
<option value="5.0">5.0</option>
<option value="5.25">5.25</option>
<option value="5.5">5.5</option>
<option value="5.75">5.75</option>
<option value="6.0">6.0</option>
<option value="6.25">6.25</option>
<option value="6.5">6.5</option>
<option value="6.75">6.75</option>
<option value="7.0">7.0</option>
<option value="7.25">7.25</option>
<option value="7.5">7.5</option>
<option value="7.75">7.75</option>
<option value="8.0">8.0</option>
<option value="8.25">8.25</option>
<option value="8.5">8.5</option>
<option value="8.75">8.75</option>
<option value="9.0">9.0</option>
<option value="9.25">9.25</option>
<option value="9.5">9.5</option>
<option value="9.75">9.75</option>
<option value="10.0">10.0</option>
</select>
Set hidden form element on the cart page cart.php
<input name="SkirtLength" type="hidden" id="SkirtLength" value="<?php echo((isset($_POST["SkirtLength"]))?$_POST["SkirtLength"]:"") ?>" />
Then set session value on cart page cart.php
Then edited ECart Charges page - based on session variable value (is greater than 6.0) to add $12 as a flat rate charge
It doesn't pick up the charges to show in the order summary.
Hope you can help
