Testing live and order receipt page is not rendering
Thread began 6/07/2010 8:23 pm by dave403891 | Last modified 6/14/2010 6:37 pm by Jimmy Wu | 1815 views | 16 replies |
dave403891
Back again. Using eCart 5 on OS10X. I reset Authorize.net to process locally, but when testing live I hit checkout on the confirm page and get the attached messages. I'm so close. What do I do now?
Although the receipt page isn't rendering, I am receiving the receipt, and an acknowledgment email with each test order I've tried.
Jimmy Wu
Could you zip up and attach the two files that are referenced in those errors so we can take a look at them?
dave403891
Here you go.
confirm.php.zip
mailformatting_php.php.zip
dave403891
Jimmy,
My earlier thread, "eCart5/confirm page fails to load payment page," was resolved, but this thread is not. When I redid the checkout pages for local processing, rather than the "order receipt page" rendering, I received the message that I attached earlier.
You then asked for the zip files to study which I also attached earlier.
I'm writing this hoping that there is no confusion between this thread and the earlier thread.
Please help me resolve this because it's the last thing left for me to do on this project before handing the site off for browser testing.
Many thanks
Jimmy Wu
Oh, there's no confusion at all. The issue with this is that there are a few values that were set as undefined, rather than numerical values on the confirm.php page:
$BurstSize = undefined;
$BurstTime = undefined;
$WaitTime = undefined;
If you change these to this:
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
the issue should be resolved.
dave403891
Jimmy,
Like magic except for the little "Unknown column "IP9012" in the 'field list'" message that still remains. In this case, IP9012, is one of my title_id numbers from the product table.
I've gone into the orderdetails table and changed the DetailProductID from int to varchar, but the problem persists.
We're so close. What do you suggest?
Jimmy Wu
In your add to cart button, you will have to change the type in there as well, so that it will format the variable into a string rather than trying to insert an integer value.
dave403891
Jimmy,
Ever the neophyte, how do I do that? In my add to cart buttons the type for the Product_ID is hidden. What's showing up on the order receipt (at least on the copy that is coming back in my acknowledgment eamil) is a question-mark icon instead of product image. Once again, I'm stumped.
Jimmy Wu
Oh, sorry, what I meant was in the column section of your eCart object. Sorry for that mistake there.
dave403891
Thanks Jimmy.
I checked the eCart object. I've attached a screen shot of the columns window. I have text selected for the ID. My images all load in the shopping cart. I had this problem once before and resolved it by changing the type in the database table from int to varchar. That doesn't seem to have resolved this issue with respect to the order receipt page. If you go back and look at the earlier screen shot, you'll see that pesky error message on the last line.
What am I missing?
Could this have anything to do with the fact that I'm running in the test mode with authorize.net?
