Not compatible with CSS Sculptor 2?
Thread began 6/03/2010 6:46 am by Dipo | Last modified 6/03/2010 12:24 pm by Neil Beadle | 682 views | 1 replies |
Dipo
I have CSS Sculptor 2.0.4 installed, but when I try to import a preset design into Site Sculptor the option for CSS Sculptor says its not installed. Do I need to upgrade to CSS Sculptor 3? I dont really need the extra features, I'm happy with CSS sculptor 2.
Neil Beadle
Site Sculptor only allows you to import CSS Sculptor presets from version 3.
However, this doesn't stop you from using your presets in Site Sculptor. Regardless of what version of CSS Sculptor you own, you will probably want to create a page from your CSS Sculptor preset that you can then turn into a Dreamweaver template prior to entering Site Sculptor.
The reason for this is so that you can add additional editable regions to your template that will be turned into content areas in your CMS. If you go directly from CSS Sculptor to Site Sculptor, you are going to only have the one main content area for all the pages.
-Neil
