DataAssist content showing up under Template
Thread began 6/02/2010 6:54 pm by dante406918 | Last modified 6/08/2010 9:57 am by Jimmy Wu | 2761 views | 9 replies |
dante406918
Few questions about data assist:
I just got the dynamic suite few weeks ago. I am trying to build a e-store. To make the story short. I follow the blue sky music starting guide for data assist, but at the moment I am trying to implement the same steps to my own template all the information that data assist creates go to the back of my template. What do I need to do to fix it?
Also, I read on the data assist forum that in order to sell stuff I need to change from administrative to public view. Is it that true? and if it is that true. Where can I find a guide to do it?
Thank you and have a good day.
htm211248644
If you follow the directions from the tutorial, it will have you set up a backend view (which is called Administration). The setting to change it to "public" view is on the results step of the wizard. There is a drop down which by default is set to "Administration". Change it to "Public".
dante406918
Thanck you....
I saw the option on the wizard and I picked, but I still have the problem of all the information created by data assist showing up behind my template.
Can anyone tell me what am I doing wrong?
Thank you!
Jimmy Wu
Would you be able to attach your template so I can take a look at it? Also, are your pages set up on a hosted server? If they are, can you send me a link to them?
I'm not sure, but it may have to do with the z-index settings on your template being higher than the z-index settings of the content created by DataAssist.
dante406918
cosmeticveiga
I am building the website on XAMPP htdocs folder now. I took the webassist advise to make sure that everything work as I want it.
Also, I will send the zip file later on today.
Thank you for your help
Jimmy Wu
Sounds good, whenever you can send them would be great.
dante406918
Template
Jimmy, here is my template hope you can see it.
I was thinking about the index, but I dont know what I am doing wrong.
Thank you once again and have a good day.
dataassist.zip
dante406918
Good Template...
Jimmy,
I am being thinking about this too much and I think i missed the css file. Here is the new a good template. Hope you can tell me why Dataassist is showing up under my template.
Once again thank you and have a good weekend.
Jimmy I changed the index from my template and looks like the data assist is showing up above my template now, but now I have kind of the same problem i had before. All the information that Data Assist creates do not show up in the place I want it.
Always shows at the top left of my monitor. I did select the place I want to data assist appears, but I still having the same problem.
Any more ideas about what it could be wrong.
Thank you
template.zip
dante406918
I find the problem
Jimmy,
First of all thank you for the Index advise and also I was looking the difference between DA template and mine and I found that the template <!-- TemplateBeginEditable name="name" --> and the <!-- TemplateEndEditable --> needs to be inside your div tag not outside.
So for those who has the same problem as I did.
Remember to put your <!-- TemplateBeginEditable name="name" -->and your<!-- TemplateEndEditable --> inside your div tag.
Hope this help to someone else and Jimmy once again THX, for sure I will ask more question in the future, but for now.
You rock!
Jimmy Wu
Great to hear you were able to resolve your issue and thanks for posting it up for other users as well. If you run into any additional issues, feel free to open a new thread.
