Css 2.05 & dw cs5
I updated CSS menu 2.05. Nevertheless, none of the menus recognizes DW CS5, which was created in CS4. What to do?
Go to View->Visual Aids and make sure invisible elements is checked. Also you will have to go to Dreamweaver preferences and then the invisible elements section and make sure that scripts are checked. Then you should be able to click on the script tag to edit the menu.
