ie6 gets me down...and the content also
Thread began 5/31/2010 1:44 pm by Blikbrein | Last modified 6/03/2010 4:18 am by neilo | 817 views | 3 replies |
Blikbrein
I've modified the css of the 3 column layout site created with css sculptor and now the centre content column drops and leaves open space in ie6. The ie conditional 1 pixel zoom formatting created by css sculptor is still in tackt. The content area contains PowerCMS content which in some cases contain italic text, but I've tested and this is not the culprit.
URL: index.php
Any ideas?
neilo
Hi there,
I did a few tweaks that should have fixed it, but it still had problems.
I changed the rules for the #content div in your screen.css file to these:
#outerWrapper #contentWrapper #content {
margin-top: 0px;
margin-bottom: 0;
margin-left: 185px;
text-align: left;
padding: 10px 0;
margin-right: 185px;
It also looks as if a content management system(?) has been adding a whole lot of extraneous code to the index.php content div code which may also have been contributing to the problem.
With the page code cleaned up and the content div css tweaked, it seems to work fine.
It would also be worth surrounding your image with a new div to center it properly:
<div style="width:326px; margin:auto;">
<img src="PowerCMS/files/clip_image002(6).jpg" alt="" width="326" height="195">
</div>
I made the changes and added them to the page. I attach the page and stylesheet for your reference.
changes.zip
Blikbrein
Thank you. I implemented the changes. Basically changing the margins to 185px both sides. The CMS still messes with the ie6 layout and drops the content. There isn't anything I can do about that...I think...
neilo
Hello again,
Apologies, - I sent the wrong code.
Please could you try this for your content div CSS?
margin-top: 0px;
margin-bottom: 0;
margin-left: 185px;
text-align: left;
padding: 15px 0 10px 0;
width: 490px;
IE7/6 needs the width of the divs to be defined. (and the right margin isn't necessary).
There is a huge ammount of unnecessary mark-up being added because your client seems to be pasting content into the CMS Editor window straight from MS Word.
If you want to prevent that, in YourCMSdirectory/HTMLEditor/custom/ directory edit the following files:
For PowerCMS1:
contents_insert_ContentValue1.js
contents_update_ContentValue1.js
For PowerCMS2:
contents_insert_ContentValue1.php
contents_update_ContentValue1.php
and set the values of the following lines (somewhere near lines 43-44) to:
FCKConfig.ForcePasteAsPlainText = true;
FCKConfig.CleanWordKeepsStructure = false;
That will stop the bloated MSWord code from weighing down your pages. Alternatively, you could ask your client to paste from a plain-text editor (such as Notepad) and you could add your site styles to the 'Style' selector list in the editor toolbar, so all formatting and layout can be managed from there.
