Captcha Does not Display / Design View not accurate.
I recently bought CSS Form Builder in order to generate Contact Forms. To say the least, I am very disappointed.
First, the Design View display in Dreamweaver CS4 is not anything close to the actual output. Fields overlap, they are in the wrong position. It is impossible to tell what the form will look like.
Second, I can't access the help file, since Flash Player keeps saying the site isn't secure, no matter what I do to change the Flash Payer security settings. Whoever thinks Flash Player is the way to display information apparently doesn't want to share that information.
So I now have a basis form that I used to get started, have no way to modify it and see what I am doing, and even the basic form doesn't work right as:
1. I can't set the E-mail address where the form should go (can't access instructions or help)
2. The CAPCHA code doesn't display so there is no way to know what to enter anyway.
I did read correctly that no knowledge of coding is required to use CSS form builder, didn't I?
Mick
