Menu Writer 2.0.4 - error on startup
Thread began 5/22/2010 1:03 pm by hearhear302530 | Last modified 5/25/2010 5:14 pm by Eric Mittman | 900 views | 5 replies |
hearhear302530
The latest version of Menu Writer is generating the error message shown below when I try to insert a new menu into a saved document. I tried deleting the WinFileCache.dat file with DW CS5 not running, dropped back to 2.0.3 which works properly, uninstalled 2.0.3 and then reinstalled 2.0.4, deleted WinFileCache.dat again...all to no avail.
Running Windows 7 64 bit, DW CS5.
zanimul379168
Originally Said By: hearhear302530
Win XP SP3 and DW CS5, seeing the same thing. Seems that it's part of the "Preview" pane as you can tell it to stop the process and it moves on, but never draws the preview.
hearhear302530
Originally Said By: zanimul379168
Yes, that's true about the Preview pane.
Have either of you tried clearing the cache file to see if it helps to resolve this issue? Here are the steps you can take for this:
Please post back and let us know if this clears up the issue you are experiencing.
hearhear302530
Yes, I did (please see first post).
I missed that somehow when I replied yesterday. I have opened a ticket for you on this issue. To update the ticket or check it's status login and visit your support history.
