Using DataAssist Query to export to XML
Thread began 5/20/2010 8:30 pm by tom92909 | Last modified 5/21/2010 5:34 pm by tom92909 | 765 views | 3 replies |
tom92909Beta Tester
I have a DataAssist query that is working.
I have a fwrite to XML export process using same DataAssist query working, but not as desired.
mysql_select_db
($database_dbconnect$dbconnect);
$query_Recordset1 "SELECT * FROM mytable GROUP BY name";
$Recordset1 mysql_query($query_Recordset1$dbconnect) or die(mysql_error());
$row_Recordset1 mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 mysql_num_rows($Recordset1);
$fp
fopen('example.xml''w+');
fwrite($fp'<?xml version="1.0" encoding="utf-8" ?>');
fwrite($fp'<content>');
do {
fwrite($fp'<item Name="'.$row_Recordset1['name'].'">');
fwrite($fp'<image="'.$row_Recordset1['image'].'">');
fwrite($fp'<text>');
fwrite($fp'<![CDATA[Lorem ipsum dolor sit amet, consectetuer.]]>');
fwrite($fp'</text>');
fwrite($fp'</image>');
fwrite($fp'</item>');
} while (
$row_Recordset1 mysql_fetch_assoc($Recordset1));
fwrite
($fp'</content>');
fclose($fp);
What I expect as a result is something like this...
html:
<content>
<item Name="FRUIT">
<image="apple.jpg">
<text>
</text>
</image>
<image="orange.jpg">
<text>
</text>
</image>
<image="pear.jpg">
<text>
</text>
</image>
</item>
<item Name="Animals">
<image="dog.jpg">
<text>
</text>
</image>
<image="cat.jpg">
<text>
</text>
</image>
</item>
<item Name="Flowers">
<image="rose.jpg">
<text>
</text>
</image>
<image="daisy.jpg">
<text>
</text>
</image>
</item>
</content>
If I use ORDER BY in stead of GROUP BY I get something closer to what I'm looking for, but it needs only to send the <item> only once per/match.
I think my query is the problem... What I'm getting instead of the above desired result is only the first record of each ("GROUP BY") <item> name. Which is exactly what the query is asking for...I need to write this XML file to match up all of the records that have the same names, write those records close that </item> and then move to the next set of <item> name matches and so on until the query is done.
What am I missing here?
tom92909Beta Tester
I've slept on it. Good morning btw. :)
Thinking out loud...
What if I created a 2nd recordset that only looked at the <item> names, and then I included another loop before the detailed loop occurs....?
<?php do {{
fwrite($fp'<item Name="'.$row_Recordset2['name'].'">');
} while (
$row_Recordset2 mysql_fetch_assoc($Recordset2));
} while (
Not sure if my syntax is even close, nor do I have time to test this out, but hopefully when I get back later today, someone will have commented on this and then I'll test it as well...
Have a great day folks!
only the one recordset is needed.
Hers what you need to do:
Before the loop create a variable for the name, and set it to blank
<?php $nameStr = ""; ?>
inside the loop add an if statement to determine if the name tag should be written. and set the value of nameStr to the value ion the recordset.
the first time, you wont need to close the name tab, but subsequent times through, you will
if($nameStr != $row_Recordset1['name']) {
  if($nameStr != "") fwrite($fp, '</item>');
  fwrite($fp, '<item Name="'.$row_Recordset1['name'].'">');
  $nameStr = $row_Recordset1['name'];
full code:
mysql_select_db
$fp
<?php $nameStr
do {
if(
  if(
$nameStr != ""fwrite($fp'</item>');
$nameStr $row_Recordset1['name'];
} while (
fwrite
($fp'</content>');
fclose($fp);
tom92909Beta Tester
Outstanding recommendation! It worked perfectly!
:D
Thank you very much!
