Line Item 1 is Invalid (authorize.net)
Thread began 5/20/2010 7:43 am by president310264 | Last modified 5/21/2010 6:35 am by Jason Byrnes | 4654 views | 3 replies |
president310264
I am building a shopping cart utilizing AIM. I am getting a response back as failed and need help interpreting the response. Here is the response…
(TESTMODE) Line item 1 is invalid. - 270
Full Request
&x_login=XXX&x_tran_key=XXX&x_version=3.1&x_invoice_num=RESUMEIMAGES_3901492_10551612&x_test_request=TRUE&x_method=CC&x_type=AUTH_CAPTURE&x_relay_response=FALSE&x_delim_data=TRUE&x_delim_char=::&x_customer_ip=205.213.92.64&x_amount=59&x_description=Networking Letters and Emails&ID=8&Name=&Description=Networking Letters and Emails&Quantity=1&Price=59&Taxable=YES&x_card_num=XXX&x_exp_date=XXX&x_card_code=XXX&x_email_customer=TRUE&x_tax_exempt=FALSE&x_first_name=Clay&x_last_name=Hess&x_address=426 N 3rd Ave&x_city=Wausau&x_state=WI&x_zip=54401&x_phone=5555555555&x_fax=&x_email=president@webolutiondesigns.com&x_country=US&x_recurring_billing=NO
Full Response
3::1::270::(TESTMODE) Line item 1 is invalid.::000000::P::0::RESUMEIMAGES_3901492::Networking Letters and Emails::59.00::CC::auth_capture::::Clay::Hess::::426 N 3rd Ave::Wausau::WI::54401::US::7152974734::::president@webolutiondesigns.com::::::::::::::::::::::::FALSE::::34A238A896BFD782CA542D37C400155F::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
Can someone please point me in the right direction?
the line item information being sent is:
your name does not have a value, authorize.net requires that the itme information have a value for the name.
president310264
Thanks...I made that change and fixed that error. Now I am receiving a different one...
(TESTMODE) An error occurred during processing. Please try again. - 59
Thoughts?
Reason code 59 doesn't really have a lot of info for it:
responsereasoncode/
Response Reason Code: 59
Response Reason Text: An error occurred in processing. Please try again in 5 minutes.
Sounds like it may be related to a problem on the authorize.net end that should be cleared if you try again in 5 minutes.
