Validation
Thread began 5/18/2010 8:04 am by david252015 | Last modified 5/18/2010 7:04 pm by Jimmy Wu | 1492 views | 5 replies |
david252015
Validation
Using validation toolkit and I need to make a text field min 6 charatcers and also have a confirm email which needs to be identical to email field.
Are there simple answers to these?
Miguel
If your using server validation for the text field select
Entry Length it will show a box with a min lenght set to 0 and a max length set to 0 just change the 0 on the min lenght to 6 leave the max on 0 wich mins no limitations on that one
For the email one its a bit more tricky, you need to add 2 fields for the email example email1 and email2
now you go tot your server validation options and select your second field email2 and add the option Like entry, it will open a box with the lightbulb click on it and look for your email1 field there clic ok and then add your show msg if validations and your set
david252015
Thanks for this - unfortunatley I am not using server side!
Miguel
its almost the same just check the behavoirs when you add them and you can modify them to your needs
david252015
Many thanks, will try this.
David
Jimmy Wu
Let us know if you run into any issues with this. It should be pretty straight forward to get the validation applied. You would also want to apply the email validation to the first email field.
