Whats the diffrent?
whn I use the UE4 upload. 2 bindings show up. which one should i use?
See attechment :-)
Denis
See attechment :-)
Denis
Denis,
I typically use the top one. There are some cases though, for example, if you were generating multiple size versions of the same upload, then you would need to go down to the next set of bindings as it DFP will create a set of binding for each individual version you create.
So, let's say you created a thumbnail of a photo, you would see the unique bindings below the set for the original image.
Best regards,
Brian
