Insert Honeypot
Hi there,
how can I insert the honeypot into my form with the wizzard? Should I insert a hidden field?
Cheers
Denis
Hi there,
Cheers
Denis
Yes, add a hidden form element, uncheck the Required attribute and add the following regular expression:
/^$/i
Do I only need to enter " /^$/i " ?
Is there nothing else to do to realize the honeypot?
I want to create a hiddenfield, that stores the DATE('Y-m-d H:i:s'). Where can I put that php-code in the wizzard?
Cheers from Cologne,
Denis
Yes, that is all that needs to be done.
A honey pot is just a hidden form element that is validated to be empty.
If a robot is filling in the form, they are usually programmed to fill in all form elements.
The wizard does not have a place for you to set form element values, you need to do that after the form is created.
This post has been deleted.
