UE4 not remembering entered fields
Thread began 5/11/2010 8:07 pm by Martin | Last modified 5/12/2010 10:47 am by Jason Byrnes | 605 views | 1 replies |
Martin
Greetings,
Finally started using UE4 extensively and I notice some interface bugs that have cropped up again that were solved in UE3.
I have attached 4 images to show you what I mean.
Image 1 - In this image I am re-opening an already created UE e-mail. You can see that the previously programmed trigger choice is missing.
Image 2 - You can see I have entered the trigger choice and I am now selecting the Advanced From.
Image 3 - You can see that my From Name is now empty, I can confirm that this happens every time I go to the advanced tab.
Image 4 - I return to main UI, you can now see that the trigger has changed from the specific button I had earlier selected to "any form post".
I must also comment that when entering in subject fields that adding a dynamic element causes the field to erase anything previously entered. Again another UI element that used to be fixed by tabbing to save the field, but now it just deletes it.
I hope you can address these issues, it makes it annoying to use this extension and to have to keep re-entering info.
Thanks,
Martin
login.php
