Populating/adding discounts for signed in users
Thread began 5/11/2010 2:57 pm by mora398588 | Last modified 5/27/2010 11:13 pm by mora398588 | 844 views | 4 replies |
mora398588
Is it possible to configure e-cart to automatically insert a discount (for example 15%) off the total sale price for a signed in user without having the user enter a discount code? I would like to extend discounts to certain users (with appropriate security access) and have the checkout process automatically populate a discount when logged in.
If this is possible, could you offer some guidance / direction on how to configure the process. Your assistance would be greatly appreciated.
yes, this is possible.
First you will need to create the user levels, see the "User Level Authentication" tutorial on the security assist support page:
securityassist/
The basic idea, is that when the user logs in, a session is created that contains their user level.
in the recipe, the session is named userLevel, and it gets set to 1, 2 or three.
to assign the discount is exactly the same as the coupon code recipe, just use the userLevel session variable, and change the value being compared to be the same as the userlevel should apply to.
mora398588
I am now attempting to create the discount recipe. However, after reading your recommendation, it is my understanding that I will be creating a coupon code feature as covered in your solution recipes page. I was hoping that I would not have to have my account users enter a coupon code, but that the discount be automatically populated and applied just by being logged it.
I have already created the user authorizations using securityassist. Is it possible to have ecart automatically apply a discount to the total amount without the enter of a coupon code for the signed in user?
the difference, is that in the coupon code recipe, you use a form value to set the session variable. In this case, the form is not needed, the session is automatically created at login time.
Ignore the portions of the coupon code recipe that deal with creating the form, you are only paying attention to the portion that deals with creating the discount rule.
mora398588
Thank you for clarifying the issue. I will give this a try and let you know if it is working.
