Files upload but huge error displays
Thread began 5/11/2010 6:45 am by ajensen80796 | Last modified 5/12/2010 7:02 am by Jason Byrnes | 1064 views | 1 replies |
ajensen80796
index.php
I've got this form submitting to a folder with 777 permissions, but when I submit a file I get the following:
Warning: move_uploaded_file(/export/home/docsroot/media/WA_DigitalFilePro/../5c90a7813c5997f26abdc475b436b559_tmp.JPG) [function.move-uploaded-file]: failed to open stream: Permission denied in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/var/tmp/phpqXaOtw' to '/export/home/docsroot/media/WA_DigitalFilePro/../5c90a7813c5997f26abdc475b436b559_tmp.JPG' in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy(/export/home/docsroot/media/WA_DigitalFilePro/../5c90a7813c5997f26abdc475b436b559_tmp.JPG) [function.copy]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: move_uploaded_file(/export/home/docsroot/media/WA_DigitalFilePro/../5e95e3dd782573d8f4a25f7e6f5f7950_tmp.JPG) [function.move-uploaded-file]: failed to open stream: Permission denied in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/var/tmp/phpqXaOtw' to '/export/home/docsroot/media/WA_DigitalFilePro/../5e95e3dd782573d8f4a25f7e6f5f7950_tmp.JPG' in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy(/export/home/docsroot/media/WA_DigitalFilePro/../5e95e3dd782573d8f4a25f7e6f5f7950_tmp.JPG) [function.copy]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: mkdir() [function.mkdir]: File exists in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 30
Warning: move_uploaded_file(/export/home/docsroot/media/WA_DigitalFilePro/http://media.discoverneo.com/WA_DigitalFilePro/ed29d02639252dad03ba8c021c1ca352_tmp.JPG) [function.move-uploaded-file]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/var/tmp/phpqXaOtw' to '/export/home/docsroot/media/WA_DigitalFilePro/http://media.discoverneo.com/WA_DigitalFilePro/ed29d02639252dad03ba8c021c1ca352_tmp.JPG' in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy(/export/home/docsroot/media/WA_DigitalFilePro/http://media.discoverneo.com/WA_DigitalFilePro/ed29d02639252dad03ba8c021c1ca352_tmp.JPG) [function.copy]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: move_uploaded_file(/export/home/docsroot/media/WA_DigitalFilePro/../9efd11fcf63a8ddaa44cc1af82ff77cb_tmp.JPG) [function.move-uploaded-file]: failed to open stream: Permission denied in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/var/tmp/phpqXaOtw' to '/export/home/docsroot/media/WA_DigitalFilePro/../9efd11fcf63a8ddaa44cc1af82ff77cb_tmp.JPG' in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy(/export/home/docsroot/media/WA_DigitalFilePro/../9efd11fcf63a8ddaa44cc1af82ff77cb_tmp.JPG) [function.copy]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: mkdir() [function.mkdir]: Permission denied in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 30
Warning: move_uploaded_file(/export/home/docsroot/media/uploads/37a8fc67b642f08e7d3f8602afe059a2_tmp.JPG) [function.move-uploaded-file]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/var/tmp/phpqXaOtw' to '/export/home/docsroot/media/uploads/37a8fc67b642f08e7d3f8602afe059a2_tmp.JPG' in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy(/export/home/docsroot/media/uploads/37a8fc67b642f08e7d3f8602afe059a2_tmp.JPG) [function.copy]: failed to open stream: No such file or directory in /export/home/docsroot/media/WA_DigitalFilePro/HelperPHP.php on line 98
Some server will have Glitches with folders set to 777 permissions. try changing the level to either 766 or 666.
When a file is uploaded to the server, It should inherit the permissions of the folder it is uploaded to, for some reason, this is not the case on your server, you will need to work with the host to determine why the uploaded file is not being created with the proper permissions.
