Vertical Menu not displaying correctly
Thread began 5/07/2010 4:14 pm by jhmblvd | Last modified 5/10/2010 5:26 pm by Jimmy Wu | 1546 views | 3 replies |
jhmblvd
Hi, I'm building a vertical menu and when I do the menu has gaps between the menu items, as if there were a margin setting somewhere that separates the <li> items. Because my pages are all in PHP it's hard to track down the CSS using DW CS4 alt-click tool. I have gone through all the CSS and all the margin and padding settings seem to be right.
I then tried to just replace the menu using another menu and the same thing happened.
A space is inserted between menu items, and all margins are set to 0 all padding is set to the default.
Any suggestions how I can track this down?
Jimmy Wu
Does this happen in all browsers or just specific ones? Can you post a link so I can take a look at the behavior?
jhmblvd
Yes it happens in all browsers
events.php
Jimmy Wu
in your text.css file for the li, you have margin-bottom specified as 0.7em. This is what is causing the spacing to occur.
