ecart install problems
hello, im trying to set up my ecart..im working on a local testing server..ive added the database and while trying to add object im recieving this error:
Adobe flash player has stopped a potentially unsafe operation
The following local application on your computer or network:
C:\Users\xxxxx\AppData\Roaming\Adobe\Dreamweaver%20CS4\...\wf_master.swf
Is trying to communicate with this Internet-enabled location:
C:\Users\xxxxx\AppData\Roaming\Adobe|Dreamweaver CS4\...\wf_master.htm
To let this this application communicate with the internet, click settings.
You must restart the application after changing your settings
i then went to the settings tab as suggested and imput:
inside of ---Adobe flash player settings manager/
Global security settings/
always trust files from these locations [ C:/xxxxxx]
any ideas how i can work around this obstacle.. thanks in advance
