Security Assist Registration Page Email Already Exists Validation Always Shows
Thread began 5/05/2010 8:11 pm by dlovas275157 | Last modified 5/06/2010 3:35 pm by Jason Byrnes | 2193 views | 3 replies |
dlovas275157
I have two issues with my registration page, and need help.
Problem 1:
In the SA Wizard I opted for the registration form to redirect to emailDupe.php if the email is already used. This does not seem to work. Instead the page reloads with the message "Duplicate Entry 'my@domain.com' for key 2.
Problem 2:
I created a rsEmailLookup to see if the email address in the form is already used min-1 max0 numeric validation. Then I wrapped an error message in a validation show if. BUT the error shows every time even if the email doesn't exist in the database.
Attached is my page code. Appreciate any help.
index.php.zip
The behavior that is used to redirect to another page if the email already exists is the Dreamweaver Check New user Name behavior.
You cannot use both the Check new User Name and Validation toolkit to check the email address at the same time.
The validation toolkit behavior is being triggered first, and causing the first probelm you report, you will need to choose between one or the other, you can do both.
The issue with validation toolkit, is that the code for the recordset is at line 87 - 95, this is after the validation toolkit code. When validation toolkit is validating the recordset, it has not been created yet.
The validation code is at line 9 - 33, move that code black to line 99 so that it is after the record set is created.
dlovas275157
Thanks Jason.
That worked!
Solution:
1. I remove the code for the "Check New Username" SB.
2. Moved my rs code for rsEmailLookup above the validation code.
In the end, I an just using WA Server Validation on the userEmail formfield.
Thanks again. Appreciate the prompt response too.
D.
glad to hear it is working.
