Contact form
When I fill out my contact form it says 404 Not Found. I have used the contact form extension to create it.
Thank you. Cynthia
Thank you. Cynthia
please provide a link where we can see the problem.
I deleted the file, but it did not fix my problem.
Cynthia
The 404 not found error most likely means you did not upload all the files to your server or did not keep the file structure the same when you uploaded. Make sure you upload all the files that came with the solution pack and try it again. If you still get a 404 not found error, post up a link to the page and I will give it a test.
