"Connections" issue on upload
Thread began 5/03/2010 11:15 am by kdavid379212 | Last modified 5/04/2010 12:19 pm by Jason Byrnes | 1621 views | 5 replies |
kdavid379212
Hello,
I was attempting to use Universal Email 4 on a client and it keeps failing on me. After creating a simple email script, I attempt to upload by pressing F12 and am presented with an error stating that the Connections cannot be uploaded. I manually uploaded all accociated files and the page comes up, but fails to send out an email and returns a black page once the submit button is pressed.
I've uploaded all relevant files in hopes that you can figure this one out.
Thanks,
Kent
100503dm-log.txt
mail_php.php.txt
mailformatting_php.php.txt
reportissue.php.txt
waue_reportissue_1.php.txt
I'm assuming ***.php is not the real name of the connection file, right?
the error:
Connections\***.php - same - not transferred
only means that the version on the server and the local version are the same, so it doesnt need to be uploaded.
when a page is displaying blank, it means a php error has occured, add the following code to line 1 of your page to turn error reporting on:
error_reporting
(E_ALL);
ini('display_errors','on');
report back the text of error so we can investigate the cause.
To send PHP files with your post, please compress them into a zip archive and attach the zip file.
kdavid379212
Had to do a little workaround to get the errors to show up. I've attached the two files I used to get the following error message:
Fatal error: Call to undefined function: session_commit() in /home/testserver/public_html/100504mailtest.php on line 54
PHP_Email.zip
ok, change line 54:
session_commit();
session_write_close();
kdavid379212
I had to change the 8 or so instances of this in this file and the mail_php.php, but it works now. Thanks!
great glad to hear it is working.
