Product Categories
Thread began 5/03/2010 12:58 pm by mrobben375515 | Last modified 5/10/2010 8:43 pm by Jimmy Wu | 1067 views | 7 replies |
mrobben375515
Product Categories
So I made several Product Categories in my PS3 Admin section. I want to link them to the menu so the menu drops down and the Product Categories show up and then when you hover on each Product Category and the Sub Categories show up to the right of that on the 2nd level. How do I do this. I don't see any table in the database to connect to. When I connect to product categories all that shows up is the numbers. Please give me some tips...thanks
Jimmy Wu
The menus should already have the category and subcategory menus set up like that. They show up in the Product menu and display the categories there. Is there a reason this won't work for you?
mrobben375515
For some reason it's not that way. I think I may have messed with the menu. The url is 1to1marketing-inc.com. I've attached 2 jpgs showing you the options I've chosen in DW for the CSS Menu Writer...
Jimmy Wu
If you edit the menu using CSS Menu Writer, the sorting on the menu stops working, since it is a complex query. You will have to copy the query from the default files and replace it with the current query to get the menu to function like the default files.
mrobben375515
So Should I Copy Paste All of the Files from the downloaded PS3 CSS Menu Writer/Home Folder in my downloads into the root site CSS Menu Writer/Home folder? Will that work?
Jimmy Wu
That should work. I would make a backup of the current directory and then make the replacement.
mrobben375515
That worked, but when I edited the other links...not the products links...the menu went back to how it was. I didn't even touch the product dynamic links. Can I not edit the menu at all?
Jimmy Wu
The menu is too complicated to make modifications using Menu Writer. Some of the code was added after applying the menu, so it gets overwritten when you edit with Menu Writer. Its not recommended to modify the menu using Menu Writer.
