Form info repeating in email after modifying the block template
Thread began 5/01/2010 11:40 am by elevy388997 | Last modified 5/14/2010 3:03 pm by Eric Mittman | 4120 views | 7 replies |
elevy388997Beta Tester
Hello,
I have a working contact form but when I get the email I have every field sent to me 3 times. It will send all the information once, then repeat, then repeat. So for example: Name, Email, Comments. Then below that, Name, Email, Comments...etc
If I leave the "default block" email page settings, it sends the email fine, no replication BUT in front of the field names is the name of the form. So instead of seeing "Name: Ed", I get "Contact_me_group_Name: Ed".
Please post back with the page in question and a copy of your webassist folder from the site. I would like to see the page with the form on it and the file used for the message body to get a better idea of what is going on.
Here is the page with the contact form on it:
contactus.html
Here is the contact form:
framecontactus.php
This is the email i get:
"Form Submitted 5-9-2010 | 11:11 PM EDT
Email:Test@email.com
Comments: Test comments box for the contact form and I am making it longer to see how it looks in the email that gets sent.
Ok, in the template file it is still setup to loop over the individual elements that are posted. So you will see the info repeated for each posted element. To make it so you only see the info once you will want to remove the code that is in webassist > email > templates Block.php on lines 43-46 and lines 55-58.
Here is a copy of the page minus these lines, it should give you the result you are looking for.
Block.zip
Hmm, I copied over my Block file with the one you attach and it still sends me 3 sets of data. When I looked at the file and the corresponding lines you said to delete..they seemed to be random <td> and <table> tags?
And I don't know if it is something I did, don't think so, but now the whole site in Firefox looks messed up and the emails take incredibly long to get to my inbox.
It looks like I accidentally posted the same version of the block file that you posted. I'm ensuring that the updated one is posted to this reply. Here is the code that should be removed from the specified lines:
43-46
foreach( $_POST as $pkey => $pval ){
  if (!
RemoveValue($pkey,$remove,$removeBegins,$removeEnds,$removeIncludes))  {
55-58
This is just an included email template file, making changes to this file will not have an effect on the look of the site or how long the emails take to send. It sounds like you may have adjusted the css if you are seeing things differently in the browser.
Block.zip
Perfect! It works now, I deleted the first set of lines you mentioned, without thinking that when that happens, there will be a new set of code in the second set I was suppose to delete.
I'm very glad to hear that. Let us know if you have any further questions.
