"Show all products" not working correctly.
Thread began 4/29/2010 9:47 am by dan322031 | Last modified 4/29/2010 12:02 pm by Jimmy Wu | 711 views | 1 replies |
Dan808
Hello,
When I go to the PowerStore3 site for the first time and I click "Show all products" it works. If I click a category on the left side it shows the products in that chosen category as it should. However, when I go back to "Show all products" it will not "Show all products". - It keeps showing the last chosen category products. Even if I go back to the home page and click "Show all products" again it only shows the products from the last chosen category. Can you give me some insight what is going on here and possibly a solution how to fix it?
www.247sign.com
Also, since I created a .htaccess file to direct all traffic to the secure https:// server it seems to be causing ADMIN to hang. It displays "Waiting for https://www.247sign.com" in the status bar - At this point it sometimes works with no problems and other times I get a "Page cannot be displayed - Diagnose connection problems".
Also, when using IE it does not display the dynamic web charts data. Firefox shows the charts with no problems.
Thanks again webassist,
I couldn't have done it without you guys.
Dan
Jimmy Wu
If you use the default files, when you click on the show all products, the link should look like this:
Products_Results.php?Search=0
When using your pages, the show all products link looks like this:
Did you make any modifications that would affect the links?
Going to the admin page login worked fine for me, how often does it not work correctly? Which version of IE are you using?
