no emails received
Thread began 4/29/2010 6:00 am by i.edwards384429 | Last modified 5/06/2010 1:12 pm by Jason Byrnes | 1083 views | 7 replies |
i.edwards384429
no emails received
Hi
created a form using the simple contact form.
ONly thing I modified was the size and the capture settings.
Then went into UE4 and used the setting below, using CC to send a copy of th form to the user.
The test email I'm filling is is a googlemail.com and the address the form is being sent to is enquiries@1stmodel......co.uk
No emails are received at either address are these settings correct?
cheers
Ian
contactus.php is the website.
from: <?php echo ((isset($_POST["Contact_me_group_Email"]))?$_POST["Contact_me_group_Email"]:""); ?>
to: enquiries@istmodelagency.co.uk
cc: <?php echo ((isset($_POST["Contact_me_group_Email"]))?$_POST["Contact_me_group_Email"]:""); ?>
i.edwards384429
more info
Forgot to say that I did make sure that the following line was in mail_php.php because I know my ISP needs it
$mailObj = mail($mailTo,$mailSubject,$mailContent,$mailHeader, "-f".$mailFrom);
the email feild in your form is "Submit_group_Email":
<input id="Submit_group_Email" name="Submit_group_Email" type="text" value="" class="formTextfield_Large" tabindex="2" onblur="hideServerError('Submit_group_Email_ServerError');"/>
you should change the from and cc to:
<?php echo ((isset($_POST["Submit_group_Email"]))?$_POST["Submit_group_Email"]:""); ?>
i.edwards384429
update
Thanks Jason
I'll try it when I get back on Tuesday
cheers
Ian
i.edwards384429
update
Hi Jason
thewaters get muddier!¬!!
Ok the email is now sent as a copy to the sender but no email is received by the form owner and the content os the content area are not included in the email.
Any ideas?
thanks
Ian
can you send a copy of your page and the Universal Email folder so I can look at the code.
i.edwards384429
update
So0rry Jason
thought I'd posted that I sorted it ( more by luck than skill)
I know my ISP need the senders details -f bit but I assumed that that was in place when the confirmation email was sent to the form filler. Apparently not because ticking the advanced box solved the problem.
As to the email content , once I ticked the box to create a file for the email the content was shown.
So probrem solved.
I'm on another issue now thats in another string
cheers
Ian
OK, great, glad to hear it is sorted.
