javascript error with insert record in CS4
I contacted Adobe support today and they said to get on these forums as they cant help with coding errors.
When i try to insert a Record I get the following error:
while executing onLoad in InsertRecord.htm, the following JavaScript error(s) occurred:
At line 665 of file "C:\Program Files\Adobe DreamweaverCS4\Configaration\ServerBehaviours\PHP_MySQL\InsertRecord.js":
name has no properties
Line 655
if (columnName.toUpperCase() == name.toUpperCase())
Im running Win 7 64bit
I have formatted my Pc and reinstalled and the same error comes up. If I try to edit and existing insert record it works fine, when I create a new page and then try to add a new insert recordset i get this erro again.
i have since reinstalled Windows & 32Bit to see if that helped, nope. I have installed no extensions its a clean install.
I have done all there trouble shooting and still the problem.
I
Any help after spending a small fortune on this software.
