binding search results to repeating table?
Thread begun 4/28/2010 9:44 am by martistott342331 | Last modified 4/28/2010 1:56 pm by mr hankey | 1595 views | 3 replies |
martistott342331
I have created a search page and wish to display the results on this page. The literature states that "additional configuration is necessary to display record results on the current page".
I'm not sure about how to bind or display the data generated from the search in the repeating table. I know how to display static data in a repeating table. I don't know how to display data that is conditional to the search.
I have attached a file with the coding to date.
I appreciate your assistance.
mr hankey
Hi Martistott,
How i created my page was.
Create a results page based on a layout i wanted to display my data.
Then create a recordset in dreamweaver.
i then dragged the elements from the bindings panel i wanted to display on the page and where i wanted it.
the i ran through the search wizard and told it to use the current page name for results page, and search form and create new form.
it then runs through asking what you wanted to search and then complete.
it will add a form to the current page and should display the results when you change the search criteria on the same page.
Other than that you could run through the wizard and tick the box to include the search form on results page.
hope that helps.
cheers
martistott342331
results page, search parameters and displaying results of search
Your advice led me to a brainstorm, thanks.
I took my results page and renamed it as a search page. Then, I used DataAssist wizard on the search page and got the results to display on that page.
mr hankey
glad it helped.
