powergallery CSS
Thread began 4/28/2010 5:22 am by CraigR | Last modified 4/30/2010 2:30 am by CraigR | 1298 views | 2 replies |
CraigRBeta Tester
powergallery CSS
I am currently adding some DA pages to a powergallery site and am trying to achieve the following... 1. Rounded corners The input boxes and select list/menu elements within the powergallery forms have nice rounded corners, which appear in the browser and not in design mode. I would like my DA forms to look the same I can't find any reference to rounded corner images in the admin.css 2. Image buttons I want to replicate the image butttons in my DA forms to look similar to those in powergallery (these are purple/grey and rounded in the browser and not in design mode)
Justin Nemeth
The rounded corners are accomplished using only CSS. They will render in modern browsers such as Chrome, Firefox, and Safari. The rounded corners won't be picked up by IE however.
DW design view won't render the rounded corners, but if you switch to Live view it will.
The buttons are created in a similar way using just CSS for the rounded corners, padding, and hover effects. You can take a look at the PowerGallery CSS to see the code it is using.
Here is some more info about the CSS needed to round the corners without using images:
rounded-corners-using-css3/
-justin
CraigRBeta Tester
thanks Justin.
That really helped.
