Insert order vs Update order
Thread began 4/28/2010 1:17 am by lejohnson01403530 | Last modified 4/29/2010 3:58 pm by Jason Byrnes | 842 views | 3 replies |
lejohnson01403530
I am seeing that when I click the checkout button from the cart page (eCart 5) and then click the submit order button on the confirm page, the order gets added to both the orders and orderdetails tables. This is as expected. However, if I go right back to the cart and click checkout and submit the order again, rather than adding a new entry to the db, I see that the previous entries are updated. I was not expecting an update.
Can you explain how this is expected to work? And shouldn't the cart be cleared after an order is submitted? If so, how?
To clear the cart after an order is placed, add the following code after the closing </html> tag on the checkout success page:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
lejohnson01403530
I don't really want to unset all session vars. I have several other session vars for the site the I want to keep in place. I just want to clear the cart itself.
the cart contents are stored in a session named "<eCart Object Name>_Items", where <eCart Object Name> is the name of your eCart object.
The Order ID is stored in a session that is created by the Store order summary server behavior on the confirm page.
Double click the store order summary server behavior on the confirm page and note the name that the Order ID is being saved as.
now add the following code on the checkout success page after the closing </html> tag
if ("" == ""){
// WA_ClearSession
$clearAll FALSE;
$clearThese explode(",","OrderID,Cart_Items");
    if(
$clearAll){
        foreach (
$_SESSION as $key => $value){
            unset(
$_SESSION[$key]);
    else{
        foreach(
$clearThese as $value){
            unset(
$_SESSION[$value]);
change:
$clearThese = explode(",","OrderID,Cart_Items");
to the names of the OrderID session variable and the Cart items session variable.
