integrating PowerCMS2 and UserRegistration
I have PowerCMS2 and have just bought userREgistration - are there any guides on what bits are comment and how to integrate them in terms of the MySQL db?
thanks
thanks
In terms of the Database, the tables will not conflict, so you will not have a problem installing them using the same Database.
thanks - what about all the "similar" folders ? can we reuse the connections etc...
is it best to keep them separate sub folders?
ie :
/powercms2
/userregistration
blah
blah
ie. arethe common folders? files ?
I would recommend keeping them in separate subfolders rather than having them in the same directory.
