Edit css menu writer not showing
Thread began 4/26/2010 11:41 am by zaim405782 | Last modified 4/27/2010 12:03 pm by Jimmy Wu | 1401 views | 3 replies |
zaim405782
When I create a menu with css MW I can't find a way to get back to edit it, the property window on the bottom wan't show an option for editing
I am using Mac OS X snow leopard and DW CS3.
What am I doing wrong.
Thanks,
Zaim
Jimmy Wu
If you go into Dreamweaver preferences, go to the Invisible elements and make sure scripts is checked. In the design view of your page, click on the script tag for the menu and the edit should show up.
zaim405782
Current link
Thanks I got that to work, but here is another issue I can't seem to get the current link to work.
In the css I see a "ul#cssmw > li.current > a.current" but when I apply it nothing happens.
How do I fix this.
Jimmy Wu
What are you setting the current settings to? The settings will determine how and what the css is applied for the menus.
