How do you change an item in Forms?
Is is possible to reinter the form wizzard and change items in the form after it has been created?
Yes, if you select the form, there should be edit buttons in the properties inspector. One for edit form, edit design and edit contents. If you click edit form, the form builder interface will open again so you can edit the form. If you click on edit design or edit contents, it will open the two edit interfaces under form and design on the main form builder wizard.
