Error after uploading to Web Hosting Provider
Thread began 4/25/2010 1:45 pm by dominick398521 | Last modified 4/26/2010 10:57 am by Jason Byrnes | 768 views | 1 replies |
dominick398521
Hello,
I created a site using SAP and uploaded it to GoDaddy webhosting however I received the following error...
Fatal error: Call to undefined function: virtual() in /home/content/47/5140147/html/index.php on line 53
It looks to me like all the files uploaded properly. Any ideas?
Thanks,
Dominick
Dreamweaver will use the virtual() function for attaching php pages when the Dreamweaver site is configured to "Create Links Relative to:" "Site". if you change this setting to "Document", Dreamweaver will use the require_once() function instead.
The virtual() function is only available in some Apache server environments.
Go to Site -> Manage Sites. in the site manager, select your site and click the edit button. On the local info tab, change the "Create Links Relative to:" option to "Document"
after making this change, you will need to edit or recreate the site assist site for it to regenerate the code.
