can site assist be used with flash navigation and header?
can site assist be use with flash navigation and a header to make a full site so when i click the links the top of the page has an animation feature?
Here is an example 3283.html
you can change out the menu that is created by site assist with your own menu using flash, but Site Assist will not be able to manage the site links for you, you would need to create the flash menu structure and links yourself.
In this case, Site Assist will create the site pages for you, but you will need to create the flash menu yourself.
