when overwriting a css design
Thread began 4/23/2010 8:57 pm by purchaser400692 | Last modified 5/10/2010 1:48 pm by Jimmy Wu | 811 views | 3 replies |
purchaser400692
when saving a design that you edited it increments the file name not overwriting it like the program says it is.
what gives?
Jimmy Wu
I just tested this and I wasn't able to reproduce the behavior. Does this happen for every layout that you try to overwrite?
elevy388997Beta Tester
Mine is also having problems as when I start changing the Type it adds numbers after the tags:
From Header .... to.... Header2323232323
It also keeps opening up the templates instead of adding the changes I put on it. i don't know what it is but CSS Sculptor has been very buggy on me recently making it impossible to get these layouts created that I need. Sometimes it doesn't let me change the heights of the topnavigation area, other times I can't change colors on the background for topnavigation. If you would like pictures or anything, let me know.
Jimmy Wu
Are there any specific steps for reproduction or does it just happen sporadically when you are working on it in different areas?
