DataAssist & CSS Sculptor Template
Thread began 4/23/2010 5:13 am by office377308 | Last modified 4/30/2010 8:33 am by Jason Byrnes | 4612 views | 3 replies |
office377308
This is a deadly combination on my DW CS3 system. I don't know how often I started Data Assist Wizard now. I am lost, since I never succeed to build an admin page set using a CSS Sculptor template. The moment I click next and it reaches the second screen it freezes forever, so that Dreamweaver as a whole crashes. Is there any solution to this or must I do each and every page by hand?
Hope not ...
Another thing cought my eye:
..\Configuration\Shared\WebAssist\Library\Preview.
In Task Manager there is a process called HTML2Image.exe. It is listed 7 times as bein active.
second update:
after going to Edit -> Web Assist Preferences -> disable preview - it stopped hanging.
After having read many threads I found this is not a very uncommon problem. I think you guys have to check whats wrong with this preview module. One can use the browser which is OK for me. But I guess its not enough to answer "It's working with me".
Because obviously it does *not work* with quite a few users on different systems.
BTW, my system is Windows 7/64 - CS3
Often, this issue is caused by a conflict with the antivirus software you have running. The HTML2Image.exe program takes a screen shot of the page being previewed in IE, some antivirus programs cause the HTML2Image.exe program to crash when it tries to save the preview.
Try temporarily turning off your antivirus program to see if that is the cause of the problem in your case.
this_is_me
makes no difference, but ...
if I use CSS Menu Writer, Preview works as it should, even with Anti-Virus Software enabled.
are you selecting a template in the DataAssist wizard?
If so try not selecting the template, does the preview work without a template?
What version of data assist are you using?
