Adding a form to a product
Thread began 4/22/2010 9:03 pm by bhwebdesign330086 | Last modified 4/26/2010 8:01 pm by Eric Mittman | 748 views | 3 replies |
bhwebdesign330086
I am building a store for a client. He has many different products but two of them require that the customer provide more information. We added field to the page with the product description. Does powerstore support the cgi needed to send that info to where it needs to go? Can I just create the form on the product page and use cgi in the store to send the data or is there a better way to collect this info and send it via email?
Modifying PowerStore to include these fields in the product details page would probably be the best way to go about this. This is a little custom but it should not require any hand coding. You would want to add these fields to your order details table, then you can add the form fields to the to the add to cart form on the product details page.
Next you would need to update the cart using eCart to include these new columns for the requested data. Then on the confirm page you would want to update the store order details server behavior to and associate the newly added cart columns with the new columns in the order details table.
As you can see there are a few steps to the process but it is possible if you have eCart.
bhwebdesign330086
Thanks for the quick response. I am really new to powestore and ecart so I am not following you on this. I have added the fields to the product page but not sure how to get the submit button to work. And I am not sure what you mean by adding the form again to another page and then adding columns.
Please help
Bruce
Did you add the fields to your db to record these values? If so you can add them to your page with the add to cart on it. In the product details page you need to ensure that you have the new form fields added to the cart form on the page. Once the form fields have been added any values that are entered into them when the add to cart button is pressed will be posted along with the other values for the item.
Once you have got that going you will need to update your cart to add in the new columns. The new columns will be named similar to your form elements. You need these columns to be able to store the info that is entered on the product details page in your cart.
Once you have done all of that you are ready to alter the add to cart server behavior. When you do this you will select the newly added columns and for their value you will select the new form fields you have added into the 'add to cart' form on the page. This is what you need to do to get it adding to the cart. Once you do that you can then edit the confirm pages to ensure you are storing the info in the db.
