Password
is there a way to retrieve a password for admin login; i forgot one
:rolleyes:
PeterL
:rolleyes:
PeterL
If you are using PowerCMS 2, you can go into your database, you can check the login information there. There should be a table for pcms2_users that stores the information.
If you are using PowerCMS 1, you will have to check in the WA_Globals file, where you specified the username and password.
