CSS Menu 500 internal error
Thread began 4/21/2010 10:04 am by xag | Last modified 4/21/2010 11:26 am by xag | 618 views | 2 replies |
xag
Hello,
I am trying to insert a menu into my index page and when I use the webassist insert CSSMenu it keeps putting in the following code for the menu
<?php virtual("//CSSMenuWriter/cssmw/menu.php"); ?>
once I upload all the folders and everything to the test server I get a 500 internal server error. Also the menu doesn't show up in the design view of DW... but when I take out one of the "/" in the above code it does show up in DW but still nothing on the test server.. anyone have any suggestions for me?
the virtual function is only valid on a small handful of server.
Dreamweaver will use the virtual function for include references if you set the "Create Links Relative To" option on the Local Info tab of your site definition to "Server". Change that setting to "Document" instead so that Dreamweaver will use the require_once function instead.
xag
Gracias Jason!
