Template not using editable region
The attached file was mae using the main editable region, why is the form built below it?
Nick
Nick
the form is contained inside the main editabel region:
<div id="content"><!-- InstanceBeginEditable name="main" -->
<table width="90%">
<tr>
<td><p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p></td>
</tr>
</table>
<div class="WADADeleteContainer">
<?php if ($totalRows_WADAgallery > 0) { // Show if recordset not empty ?>
<form action="gallery_Delete.php?key_img=<?php echo(rawurlencode($row_WADAgallery['key_img'])); ?>" method="post" name="WADADeleteForm" id="WADADeleteForm">
<div class="WADAHeader">Delete Record</div>
<div class="WADAHorizLine"><img src="../../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<p class="WADAMessage">Are you sure you want to delete the following record?</p>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">ID</th>
<td class="WADADataTableCell"><?php echo($row_WADAgallery['key_img']); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">Album</th>
<td class="WADADataTableCell"><?php echo($row_WADAgallery['album_img']); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">File Name</th>
<td class="WADADataTableCell"><?php echo($row_WADAgallery['filename_img']); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">Caption</th>
<td class="WADADataTableCell"><?php echo($row_WADAgallery['caption_img']); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">date_img:</th>
<td class="WADADataTableCell"><?php echo($row_WADAgallery['date_img']); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">edate_img:</th>
<td class="WADADataTableCell"><?php echo($row_WADAgallery['edate_img']); ?></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Delete" id="Delete" value="Delete" alt="Delete" src="../../WA_DataAssist/images/Pacifica/Refined_delete.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="gallery_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../../WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADADeleteRecordID" type="hidden" id="WADADeleteRecordID" value="<?php echo(rawurlencode($row_WADAgallery['key_img'])); ?>" />
</div>
</form>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAgallery == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">No record found.</div>
</div>
<?php } // Show if recordset empty ?>
</div>
<!-- InstanceEndEditable -->
it looks like you had a table already inside the main editable region:
<table width="90%">
<tr>
<td><p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p></td>
</tr>
</table>
data assist will not replace what is inside the editable region, it will only add to the editable region. It added the Data Assist form after the table that was already there.
Thanks for the reply - saved me time....
