Adding Rules Together
Thread began 4/20/2010 5:14 am by markdoyle87077 | Last modified 4/21/2010 12:49 am by markdoyle87077 | 840 views | 2 replies |
markdoyle87077
Can you point me in the right direction. I need to add the values of 2 rules together to display in the cart. I can get the rules to display singularly using:
<%=WA_eCart_GetRuleValueByName(dmbp, "Discounts", URLDecode("VD160Q"))%>
but i want to add the following together:
<%=WA_eCart_GetRuleValueByName(dmbp, "Discounts", URLDecode("VD260Q50to99"))%>
<%=WA_eCart_GetRuleValueByName(dmbp, "Discounts", URLDecode("VD260Q100plus"))%>
Kind regards.
Mark
This would require custom coding. You should set a variable, then add the values to the variable, then you can display the variable on the page where you would like to see the info.
Session("your_var") = 0
Session("your_var") = Session("your_var") + WA_eCart_GetRuleValueByName(dmbp, "Discounts", URLDecode("VD260Q50to99"))
Session("your_var") = Session("your_var") + WA_eCart_GetRuleValueByName(dmbp, "Discounts", URLDecode("VD260Q100plus"))
Response.Write(Session("your_var"))
This is just an example of how you could do something like this, your code will need to be customized to fit your needs.
markdoyle87077
Sorted
Eric,
Thansk for the reply. I have gone downa slightly different route and combines the rules in the eCart definition file and that has now cured the problem I was trying to sort but your solution will come in handy for another area of the site. Kind regards.
Mark
