Error on upload
Cant upload files to the filemanager i only get "No file uploaded 0" (Se Attached File").
This startded when i deployd the site on a webserver.
Are you using the advanced file management? If so did you also export your db and import that to your live db? You will need to do that as well if you want it to work the same as it does locally. Please post back and include some more details if you continue to have any trouble with this.
