Jan Jensen
I can't open my Menu Maker. I get this message. Attached.
I have lokked in the instruction file but there are only one level in my Dreamweaver CS3 menu. Attached. Please help me.
Do you have a page open in Dreamweaver when you are trying to access menu writer? If not, you will have to open one before trying to open Menu Writer.
And you have a site defined within Dreamweaver that contains the file that is open?
No I did not. Now it works. Thank you.
I was a bit to quick when wrote that all did work now. I do now have defined the Site on both lokal and server, the server link works. But when i have defined the menu, and are going to exequte it i freeze. Se attatchement.
Try the steps listed here in the guide for deleting the dat file?
If that doesn't work, then you might be experiencing an issue with a corrupt configuration folder. Here are the steps that you will need to take if this is the case:
showpost.php?p=12293&postcount=2
Please let us know how this works for you.
I have done as you suggestet, the same result. I am using a Dreamweaver CS3, on an Windows 7 platform. I followed the instructions for Vista. There where none for Windows 7.
No result.
Regards
Is your site saved on a local drive or on a remote network drive?
